GriffinRU
01.12.2008, 07:37 PM
Originally Posted by DrKnow65 View Post
Yes, the newest version. Are there more than 3 generations, or less?
I've seen 4 variations so far...
Sweet. Assuming it all still works fine once the brain is reconnected to the/a powerboard, you would need to use a seperate LVC to protect your lipos (since the built-in one is turned off)? That was what I was getting at before really. You never cease to amaze me with your electrical wizardry....
I've tested 2 modified controllers with 6S for 30 minutes, running up/down/brakes with no problems. Have not tested unmoded ones.
