Mod Man
01.13.2008, 04:51 PM
I have not read this entire thread, but I can tell you that 6S with a 1512 will not be enough to hit 100 mph. My TC4 (126 mph) would not break 94 mph with a 1512 on 6S no matter what I tried. I went to a 1515 on 12S and BINGO, 108 mph on the first wound out run.
Also, stock bodies have major problems above 90 mph.
What you will find is 80 mph is not hard to hit with modern motors and packs. 90 is tougher to hit and requires actual engineering to achieve. 100 mph is an order of magnitude harder and requires some significant effort and aerodynamic R&D. 120 is EXTREMELY difficult to hit! That will require well over 3000 watts, and some crazy tires (Personally I like BSR radials). Oh, to break 100 you will need at least 1300 feet, 800 feet to accellerate, and 500 feet to stop. Radio range fast becomes an issue as well as line of sight.
You guys here on RC-Monster are at an advantage because you are already used to running big power systems. I am glad to know there are top speed guys here.
Matt
