01.13.2008, 06:45 PM
i use the same insert as you do.
It has Drag brake setting and standard brake setting. You must change the drag brake setting.
I dont use any drag brake as i use motors with very strong magnets and they brake very well on their own. In maxx even the light setting is too much.
If you have insert in as it should be you should not mess up any setting
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
