01.13.2008, 11:46 PM
Thanks for the efforts. I am sad that I was watching the Dallas game on DVR, I recorded it so that I could speed a little time outside while the sun was still up.
I should be able to post soon as I created an account.. Had to just to see the thread. However if you see one let me know, That seemed like a cheap fix for enevitable failure.
I forgot to mention that I think gearing up to the 20 tooth helped. I ran most of a pack, and motor temp came out at 130 degrees.
I am now running 20/66 gearing.
If I get a strobe with 51 tooth spur, I could run my 16 tooth pinion which would be real close to the 20/66 gearing I have now.
I really don't like the way the 20 tooth fits in. I have to put the motor on mount first which prevents me from getting the teeth aligned front to back 100% correctly. Right now the pinion only hits about 70% of the spur. With the 16 tooth I could mount pinion then assemble allowing me to get it aligned perfectly.
Highflier
