sikeston34m
sikeston34m's Avatar
01.15.2008, 12:50 AM
Originally Posted by team3six View Post
I found out the maker of the motor. It is a HiMax outrunner. That model is about 3 years old.
It is similar to this, The can style was the givaway. Most makers use certain cans for thier products. The CF Decal just didnt look right with the motor.
http://www.rctoys.com/rc-toys-and-pa...ORS-HIMAX.html
These are the older designs that I was refering to.
http://www.radicalrc.com/shop/index.php?cat=114&shop=1&
Hey you could be onto something there.
If it is a Himax motor, then it's dimensions best fit the 500 watt models:
HA3618 Brushless
500 Watts
• Designed as direct replacement for 500/550 type can motors - same diameter & mounting pattern,
• Direct replacement for B50S and Aveox 36/15 type motors,
HA3618 -This 500 watt motor is for midsize models weighing 48-62 oz for 3-D flight, up to 80 oz for aerobatic flight and up to 100 oz for leisurely flight.
HA3618-2300
HA3618-3000
HA3618-4500
http://www.maxxprod.com/mpi/mpi-2601.html
