BL-Power
BL-Power's Avatar
01.15.2008, 04:24 PM
At at total ratio of 9.58333 : 1 i'm not surprised that you have a hot motor. For your vehicle, a total radio between 13 and 15 would be normal, a 11 - 13 teeth pinion would be perfect and your motor will stay much cooler. And if it's too slow for you, go up to 5s if your MM is able to handle this voltage.
 Send a message via ICQ to BL-Power
