Originally Posted by ssspconcepts
Is it possible that the 5S balance harness is worn/defective? I had a similar but different problem that had me confused for several days...except my problem was a bad deans connector.
Now that may be a possibility. I am using one of the multi tap adapters for the balancer that has 2s - 6s taps all on one card. I will give that a check to see if it has gone bad.
