Originally Posted by johnrobholmes
Yep, solder posts are gone. Castle kept with the wires because they kept bending the posts and it was causing fitment issues.
The sidewinder would be great, but a bit big. Maybe fit it on its side? The Quark 33 would be very smooth and small. The lightning 38 ESC is pretty good too, and tiny. The L38 has great programming for crawling too. All good choices IMO, just depends on what you want. The nice part about the sidewinder is that it could make your stampede go 40mph, or your mini go a billion MPH. The sidewinder has about 1hp continuous.
Hey jrh, do you think the sidewinder will be capable of 4s? And is the software capable of supporting a neu/novak motor, to your knowledge? I only ask as it sounds like a great controller to pair up with a high quality motor for 10th scale vehicles, maybe even 4wd like the crt.5. I have a bunch of mamba max escs, but since they are not too good with the neu/aveox/novak motors, I have resorted to the quark 65 as my do-all small esc. Sounds like castle has a winner here, do they plan to keep the mamba max esc or will the sidewinder replace it? And since you have some good contacts, can we expect any sort of upgraded programming for the mamba? The rumored "neu fix" as some call it.
