Originally Posted by lincpimp
Yep, the jato spurs will just bolt on, and you can use std 32p pinions with the .8mod jato spurs. Definately a cheap upgrade. The cover will not fit on with the jato spurs, but I run mine in sand and gravel and it shows hardly any wear. I even half stripped a few teeth off the spur (the motor came loose) and just reset the correct mesh and am still running it!
by std 32p pinions do you mean these:
http://www.rc-monster.com/proddetail...od=32pinion5mm
Might be a really stupid question.
