Lonewolf039
Lonewolf039's Avatar
01.16.2008, 01:39 AM
Oupsss! could you tell me if the twin force slipper gear is 32 pitch or MOD1???
Look like to be 32 pitch
Ya, it's 32 pitch, but if converted to a revo slipper, you could use the mod 1 revo gears. If not the revo slipper, you could use an MGT spur gear with the stock slipper, they are mod 1. You just have to slightly ream out the center to fit the stock 10x6 mm bushing.
Looks like a revo slipper could be installed in place of the stock slipper. That should be able to hold up to the power. Is the shaft 5mm in diameter?
The shaft is 6 mm, but could be machined down to 5 mm. The main problem is that the revo slipper would move the gear further away from the motor. The chain sprocket already takes up a fair bit of room. Look at this pic, you can see it between the motor and slipper. The revo slipper will take up some room too.
I have been looking hard at it tho. I really want to get a decent slipper for the Twin.
