jhautz
jhautz's Avatar
01.16.2008, 02:12 PM
You could also set the throttle and brake profile curves using the MM software. You can make it feather smooth on the very bottom end with this software. Its really very nice.
Also if there is a Neutral range setting (I cant remember if there is one or not on the MM) set it to a smaller range than the default. This will minumize the "dead band" before the thottle kicks in.
to make it...
or break it...
Silent...But Deadly
