magudaman
01.16.2008, 02:45 PM
It honestly sounds like you just need to go through the initial set up again. After I did my controller has ZERO dead zone and according to the default throttle curves that come stock so should you.
Plug in a battery
7. Holding full throttle on your transmitter, turn the switch ON
A. After a few seconds you’ll hear multiple tones and the red LED will come on
B. Now hold full brake and after a few seconds you’ll hear multiple tones and the
yellow LED will come on
C. Now relax to neutral and after a few seconds you’ll hear multiple tones and ALL
the LED’s will light up
D. A few seconds later the ESC will arm with a double tone and you’re ready to go!
