Aquacraft SV27 Brushless Motor
Aquacraft SV27 Brushless Motor - 01.16.2008, 10:00 PM
Just bought one of these motors for testing purposes. From what I can find it appears to be a 6 pole motor with kv somewhere around 1800. Tower spec it at 18v max input. It has a 5mm shaft, both 25mm and 18mm bolt pattern. It is 36mm in diameter and 56mm long, about the same size as a l can feigao.
Was thinking about trying this motor in my ls10 on 5s lipo. It is a 6 pole motor, so my quark esc would most likely be the best bet. Any idea if a mm would run this motor well? How about a bk 9920? I have a plett maxximum, which is 4 poles, and a mm works it fine, with the start power all the way up.
Any info would be appreciated. I know that Lutach tested this motor, so Maybe I will hear from him!
