01.17.2008, 09:25 PM
As an alternative, you could use a 12v fans used for PC chipsets found at most computer stores. Then, use a simple LM7812 regulator off the battery pack. Might be easier to find 12v fans when/if they break or wear out.
TBH, if you're having heat trouble, you are most likely geared too high. Fans mask the problem IMO...
