01.18.2008, 11:19 AM
That is the ESC man, which got more expensive. I used 4.5" wide thick heatshrink and soldered on 3x 330uF 35Volt caps.
To enable the ESC, you have to put in it reverse after the first beep. You'll hear another beep, which tell you that the ESC is enabled.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
