Serum
Serum's Avatar
01.18.2008, 05:21 PM
Nothing negative about this auction, but I wouldn't use a 3.2mm shaft with the pinion sticking out THAT far.
Hard to tell; but is the shaft snapped of or not? If not, it will probably snap with the first couple of runs. a gearing ratio of 1:12 with that motor and a non sintered rotor will heat it up pretty badly too.
