neweuser
neweuser's Avatar
01.18.2008, 06:40 PM
I've only programmed my MM, for some reason, I want to say I initially put some settings on before connecting to the motor? Not sure if I'm right, so I would go by the manual. If the motor is not beeping, then I would check for connections. make sure you take off the pinion though....or something so the motor doesn't just take off.
