sikeston34m
sikeston34m's Avatar
01.20.2008, 07:14 PM
Hey Sike, glad that the quark is working out for you.
Are the diffs holding up better for you with the better bearings?
The teflon washers are the ones I use to shim up the axles, usually one does the job!
About the bare wire thing, you guys are joking right? I can't see the rubber coating lowering the resistance, maybe I am missing something?
I'm uploading Video's to Youtube right now. I'll post vids in a few minutes. You're gonna think this belongs on "beat your truck" or something. LOL
The Diffs held up great through the first run, and ummmmm well.........15 minutes into this run, the rear pinion bearings went out. The gears sounded like they were munching on balls.
I'm not sure what to do at this point. The 10/43 gears won't and don't hold up to this kind of power. The spiral cut loads the pinion bearing like a thrust bearing. Even the Ceramic Nitride bearings can't take it.
I might go with the 13/43 straight cut gears and try again. They will tend to side load the bearing instead of loading it like the spiral cut gears are doing. This custom Wye Wind starts better and makes more torque, so I think I still have a shot at it even with the 3.3:1 ratio.
Somebody show me a Diff that can stand it and I can make the power to shove through it. LOL
