sikeston34m
sikeston34m's Avatar
01.20.2008, 08:20 PM
Originally Posted by Mod Man View Post
I think it should be possible to shim everything just right. That should eliminate the driveline issues.
Does your ESC have a ramp up feature? I set my HV110 to slow start and it helps keep from hammering the driveline.
Awesome power. Just awesome.
Matt
I did shim everything JUST right. It was perfect.
The spiral cut gears are punching the inside race right through the bearing.
I could lower the starting power some in the ESC setup.........I guess
Thanks.
