Questions???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Questions??? - 01.21.2008, 07:48 PM
You know Sikes you might be on to something. If a belt drive was strong enough and efficient enough to drive a 700lb motorcycle, then why not come up with a scale size belt for our trucks that fits the same sort of specs? It would make things quite a bit easier for the 4X4 setup of the types of vehicles we run. Just think of it. two Harley style belts that could run directly from the motor to the drive axles. Maybe using a slipper or clutch type motor drive.
