01.22.2008, 12:41 AM
Originally Posted by Team X View Post
Do you think this would be a good set up for a Rustler?
You will need a all metal tranny in that rustler. I can safely say that a rustler setup like that would be badass!
Check this out:
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Spur Tooth Count: 54
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 2958
Tire Diameter (inches): 3.8
Spur/Pinion Ratio: 3 : 1
Total Ratio: 8.18182 : 1
Tire Circumference (inches): 11.94 inches (303.23mm)
Total Motor Speed: 43778.4 RPM
Vehicle Speed: 60.49 MPH
It would be nice to find a 2500 kv motor, in a s can, maybe a lehner basic 2400?
