Lonewolf039
Lonewolf039's Avatar
01.23.2008, 02:20 AM
Originally Posted by squeeforever View Post
You don't wanna run truggy diffs in the F/R...The ratio will be to high.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 15
Total Voltage: 14.4
Motor KV: 2084
Tire Diameter (inches): 5.8
Tire Ballooning (inches): .25
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.07 : 1
Total Ratio: 13.18667 : 1
Tire Circumference (inches): 19.79 inches (502.72mm)
Total Motor Speed: 30009.6 RPM
Vehicle Speed: 42.65 MPH (68.52km/h)
Effective Speed Rate: 2.96mph/V (4.76kmh/V)
Effective KV Value: 2084
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Don't need to go much faster than that. I have 13-16 tooth pinions on order.
