chilledoutuk
01.24.2008, 07:52 AM
Ok, just did the downlaod onto the mm in mt ext crt.5. I run a 3s 4200 lipo and a plett maximum. It does start the 4 pole motor better, and the esc seems to run cooler too. I also seem to have better runtime, like 3-5 minutes. Good stuff, can't wait to try thiws update with a aquacraft 6 pole motor in my new emaxx. We will see if it can start that motor, it is impossible to turn by hand! I also have a novak 6.5 that I eill try out in my xxx-cr buggy. Great revision for the best low cost esc around!
you have a plett max in a crt .5?
