Thread: Is this okay
Is this okay
rchippie
rchippie's Avatar
Is this okay - 01.25.2008, 10:55 PM
Is the gear ratio okay ?. Lehner 1950 8t hi amp with fp lipo's
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 1634
Tire Diameter (inches): 4.43
Tire Ballooning (inches): 0
Motor Current Draw: 60
Motor coil Ω: 0
Spur/Pinion Ratio: 2.56 : 1
Total Ratio: 8.45299 : 1
Tire Circumference (inches): 13.92 inches (353.5mm)
Total Motor Speed: 24183.2 RPM
Vehicle Speed: 37.7 MPH (60.57km/h)
Effective Speed Rate: 2.55mph/V (4.09kmh/V)
Effective KV Value: 1634
Motor Torque: 0.26 ft-lbs
Final Torque: 2.19 ft-lbs
REAL MEN RUN BRUSHLESS
