01.27.2008, 12:15 AM
I am sure that you are not stupid!
The mount base bolts to the moveable nitro motor mount. The square hole clears a part of that mount. The font plate that the motor bolts to mounts with three hex screws (use threadlocker!) and the sliding motor support mounts with 2 srews. Leave the rear support loose until you get everything lined up and the gear mesh set. Hope this helps, I do not have a pic handy, someone here will!
Reason: Cant speel
