01.27.2008, 11:06 PM
Well, I got everything together, and it looks good. My only issue is that the motor will not slide fully with the rear support installed. Not a big deal, but if you have a tight battery fitment (like I do) the extra few mm will make the difference between the gears meshing and not. I may mod the rear portion of the motor mount plate to allow for full adjustment.
Instructions are a must. I have put together at lest 40 rc vehicles and did have to sit and stare for a while. Thanks to Serum and everyone else. I only had to drill out the threads on one of the motor plate crossmembers to use as the servo brace support. Maybe this part was supposed to be included?
