Thread: I need help...
Just go Play
Just go Play's Avatar
01.27.2008, 11:36 PM
I believe there is something that has to be done when using the spectrum radios. If I recall it has to do with the amount of time it takes for the RX to sync with the TX. My best guess would be to try connecting a RX pack to your receiver so that it will be powered up and ready when you connect the power to the MGM.
You can try searching the forums as I think this was a problem for some others also.
