rchippie
rchippie's Avatar
01.28.2008, 12:22 PM
I've try my Hyperion 0610i charger today, and try to charge a FlightPower EVO25, 5000mAh, 4s pack with it. Set the charge current to 5 amps and start chargin process.
During charging, i've take a look at the screen and see the current drop to "0" for few second and then return to 5 amps.
It did it during all the charging process, so i don't take a chance and End the charge before the end.
Do they have guys here how have the same charger and experiment the same thing?????
Or this is normal on this charger??
Thank you!
David
David i just got my 610 & it does the exact same thing. David this is normal I think what the charger is doing is letting the pack seetle for a minute to get a true voltage reading & then it starts charging again. My charger did this at least 3 or 4 times charging my FP 4s 5000.
David i just got of the phone with the US distributor for hyperion. He said the charger is supposed to do what you described. This is NORMAL so do not worry .
REAL MEN RUN BRUSHLESS
