jhautz
jhautz's Avatar
01.28.2008, 10:54 PM
Originally Posted by joeling View Post
Hi,
I have a set of conversion on the way too. Looking at the few posts above, I'm a little worried about my battery choice now. I bought 2 5S 5000mah packs from HK & they are advertised as 160mm X 51mm X 40mm. The 51mm width is a concern if it has the potential not to fit. Can I turn the battery on its side so that the height is now 51mm while the width becomes 40mm ?
Regards,
Joe Ling
Yep. No problem height wise for the 51mm. Should work w/ no issues. And with a little setup work you should be able to fit the 51 in there too. Its tight for the 51, but you should be able to get it to work depending on your gearing.
to make it...
or break it...
Silent...But Deadly
