Originally Posted by Sparky
The MGM controller is adequate. It’s not the best performing controller, but right now there is no other that meets the specifications for this application. The breaking and neutral zone are inconsistent and a little hard to control. It is not a professional level controller. It’s a good sportsman class controller. I will be very competitive with it. I’m still looking for a better controlling ESC or a software patch for this one. The ESC temp was 140F after a 20 to 25min run.
The Neu motor is very good. Probably the best part of the conversion. At first I thought it was too fast. It is to fast until you change your throttle EPA “End Point Adjuster” down to around 80%. I would not use a smaller motor because this one heats up after 25min of run time. It’s very fast for a short time and will run at 1.39hp continuous use. If you start running longer the 30min you might run into heating problems with this motor. It’s a great motor and I will continue using this motor. My gearing end up at 15/46. The motor “Neu 1512 2.5df” temp was 165F after 20 to 25min run.
http://2coolfishing.com/ttmbforum/sh...5&goto=newpost
Very Nice
Wouldn't the esc and motor run cooler if the motor was at full throttle? So wouldn't a slower motor work better?
