sikeston34m
sikeston34m's Avatar
01.29.2008, 07:36 PM
Speed wise you will be limited by the largest pinion you can find and the smallest spur gear that will still allow decent gear mesh and some motor to tranny clearance. Looks like a 25/36 mod1 combo would be the minimum size. Which would give plenty of gear for almost all of the proposed setups.
Sike, what do you think the max rpm a 2826 axi can be spun up to? 15k - 20k rpm?
I have ran this setup on 6S. It runs really well on 6S too.
The motor being 920kv on 6S (22.2 volts), would top out at 20424 rpms. It makes a really high pitched whine at that speed, but it works very well. No problems.
I'm really thinking about buying the AXI 2826 8 turn. At 1130kv, it should pick up the top speed quite a bit. There is NO lack of torque. On 6S, this is going to spin up around 25,000rpms.
They seem to be VERY well balanced. I don't see a problem turning this kind of rpms. I'm going to let temps be my guide, and if I blow the windings out of one, I'll just rewind it anyway. LOL
