sikeston34m
sikeston34m's Avatar
01.29.2008, 07:42 PM
Originally Posted by Serum View Post
I am pretty sure their initial plan was to use an opti sensor on that two speed.
What temps Sike? (ambient/motor/controller?)
An opti sensor huh? Could they be planning on releasing something else that takes advantage of this? If so, I wonder what it could be?
Ambient the day of the Vids was around 45 degrees.
The motor warms up to about 115. I can sense No heat at all coming from the ESC. The ESC is oversized, but very cool running.
I may swap out the Monster Pro 125 amp for a Brand New Quark 80amp that I have on hand. The 80amp is more than enough to handle this setup I believe.
The Lipo's might have been 85-90 degrees or so.
The setup isn't very stressed at this point.
The Motor fan is required however. Also, on the 10 turn, the stator poles are wound so full, I believe it is really limiting the amount of air flow the fan will pull.
There could be a difference in this area with the 8 turn motor.
