01.29.2008, 08:30 PM
That's good to hear. I anticipate the majority of the current draw will be up to about 30-40mph and then drop to a more manageable level, so 110 should be fine. Programming it should be pretty straightforward, so hopefully won't need any help.
The only thing I'm a little concerned about is low rpm performance considering that it is geared so high. I'll know more once everything is hooked up.
