Thanks Guys. Now I'm gonna be die'in for some decent weather around here so I can test it out. I bet it wheelies alot less now with the new 2" longer wheelbase.
Originally Posted by BashOn
Nice jhautz!,
I am finishing mine as well. I noticed your brake servo setup. What type of arm/spring setup is that? It looks perfect. I used the stock Savage X SS setup and the servo arm really isn't long enough and I don't have room to use a spring.
Yea I found the same thing with the stock brake arm/linkage setup. I would love to see the servo mount plate a little wider and have the servo offset closer to the side for the brake. It would let you use the stock servo arm then. This is what I used.
http://www.horizonhobby.com/Products...ProdID=JRPA236
with this for the slider linkage
http://www3.towerhobbies.com/cgi-bin...?&I=LXNXL5&P=7
The actual connecting rods in the linkage are the stock ones and the little aluminum piece holding it all on the end of the rod is just a standard collar with a grub screw that came off of a old nitro brake assembly I ripped off of something when it was converted to electric.
I actually had all of these parts just sitting around in a parts bin left over from some other project where they didnt work out, but yes they did work out well for the arm length just by luck.
