Routybouty
01.31.2008, 12:47 AM
Not your problem but I had a different one I thought I would share.
I had a problem with binding my DX3R rx in that I could get it to bind but once I turned it off and back on the bind was lost. Turns out I powering the rx with a castle creations regulator and the ground and signal must be shorted in the reg for some reason (probably grounding of some sort). So I removed the signal wire from the regulator and bam binded and kept working.
Just my experience...
