jhautz
jhautz's Avatar
01.31.2008, 03:43 AM
One last question... when putting in all the numbers into BrianG's calculator, what do you put for the transmission gear ratio? I have all the other numbers, just not sure of that one. Also, should i add the Savage "Additional Gear Ratio" when finding the top speed or looking for the right motor to run?
Thanks again in advance.
I just choose the savage 2nd gear on a 2 speed tranny and the savage secondary gear ratio and then spur and pinion.
How well are a123 cells going to fit into this thing? With dimensions of 26x65mm it looks like it's going to be a tight fit.
I plan on rebuilding the packs into a configuration like this and then setting them on their end. they will be a 5s2p configuration and 65mm tall.
to make it...
or break it...
Silent...But Deadly
