tashpop
01.31.2008, 08:27 PM
don't know that i can add anything here except if you're using rubber tires, run with some truggy tires, they seem to hold up to high speeds better. other than that, i did what mod man said, put as much power to the ground as possible. make sure the drivetrain can take it, although if your gearing high, you might get away with the lack of torque. using such low voltage pushing a large vehical fast, you better concentrat on an esc with very high amperage capabilities. your going to want as many watts as you can get and being stuck on 11.1v means really high amps. basically twice the amps that i'm seeing in my mgm160 since i'm using 6sa123's. make sure you get some batteries with a very high discharge, you don't want to over drawl them and loose motor speed from voltage drops.
What is the distance that this "topend" should be achieved in?
Tashpop should be here giving you ideas how to get the topspeeds in a MT. He has been showing up at our drag race Test and Tunes with his beast and his goes fast.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
