BL-Power
BL-Power's Avatar
02.01.2008, 01:53 AM
Oh, I like that setup alot. Tell me, how difficult was it to get the motor hooked up in the correctplace? Looks like the shaft slid through the front bearing, then you marked the motor mount fastening positions on the existing plate, and fixed it in place
Thats exactly how i did it. It wasn't difficult at all, it took around 10min to drill the holes.
Im guessing the input gear for 2nd is retained and just fixed to the motor shaft in the correct place; any chance of a sneak-peak inside the tranny if its not too much hassle?...
I am using a 18t Mod. 1 RC-Monster Pinion instead of the input gear for 2nd. It is working great.
Thanks for your recommendations! I'll look for some Phaltline Tires for onroad runs.
I'm glad you like it, i'll see if i can make a video today.
 Send a message via ICQ to BL-Power
