johnrobholmes
johnrobholmes's Avatar
02.01.2008, 02:07 AM
I have been trying direct tire scrubbing drive over the past few days. I think I will need a wind for 36v to work proper, the 11.1v wind of the scorpion 3032 doesn't work as it overheats. The startup with a MM is also much too hard, as the tire scrubbing force is pretty great. I am seeing if I can get a proto with a knurled case. In the mean time I may try an epoxy/ sand coating. The can face speed is 15mph, which is right where I want it.
I haven't started my gearbox drive bike yet. I want pedal assist so the rear hub will be the tricky part.
