knotted
02.01.2008, 05:05 AM
I have run the stock diffs, the ones with the steel inserts and the aluminum cups, with a 1521 for a while now. They are bullet proof! No problems even with running larger, gear destroying tires like Big Joes and Jumbo Kongs. Innovative-RC is coming out with an alloy easy access diff case with larger bearings that should even solve the small bearing problem.
