Sammus
Sammus's Avatar
02.01.2008, 05:41 AM
Originally Posted by BL-Power View Post
Thats exactly how i did it. It wasn't difficult at all, it took around 10min to drill the holes.
I am using a 18t Mod. 1 RC-Monster Pinion instead of the input gear for 2nd. It is working great.
Thanks for your recommendations! I'll look for some Phaltline Tires for onroad runs.
I'm glad you like it, i'll see if i can make a video today.
Howdy, could you elaborate a bit on how your actually driving the top shaft? is that like a custom shaft you have the motor, or did was original shaft on the motor long enough so you could just bolt it to the tranny?
Also, is that shaft supported on the other side of the transmission like a topshaft normally would be?
