Originally Posted by knotted
..... Innovative-RC is coming out with an alloy easy access diff case with larger bearings that should even solve the small bearing problem.
Do youknow anythimg about the timing on these? The access part is nice, but with bigger brgs, you shouldn't need to access it much anymore!
Serum is right on - flex is the biggest prob with stock setup, 27picco was enough to destroy rear diff regularly til upgraded with alum cup, alum diff cases and bulks. I used some prem brgs (boca) and they've been fine so far.
