Originally Posted by t-maxxracer32
so i finally got a good hour- hour anda half of fun at the track today with my bl xt8 and dang that thing is fun!!! i never thought racing is fun but its awsome!!! my 1 5s2p a123 pack lasted the whole time!!
i ran in to a couple problems on the way. easy fixes im sure but some problems none the less.
after about 45 minutes of messin around my pinion and motor come loose. i figure i messed something up but when i looked at it everything was perfectly fine. just a little loose. so i tighten it back up and its good to go now. this is not the first time its happened.
should i just use some blue locktight on the pinion and motor mount?
my neu does not have a flat spot. i dont really want to grind one either... it works fine so id like to just keep it like that.
one more thing that i rememebred right now.... when i hook up my 4s a123 pack sometimes (most of the time) when i turn it on the esc just makes a stuttering noise.. like.... bmmm bmmm bmmm bmmm it will just keep going untill i unplug it. is this the low voltage kicking in?
thanks alot guys for any help!!
wow i can not believe the pinion stayed on for 45 minutes. i have my neu in my maxx with a flat spot and thread lock and it has come off twice in two 10min runs.
