lipomax
08.31.2005, 08:58 AM
If you're gonna do speed runs, running both those packs will give higher speeds than just one pack. Running one pack, the voltage will drop pretty low, but running 2 packs, the voltage will drop only 1/2 as much.
For normal bashing with correct gearing however, you don't need to run both packs.
