02.03.2008, 09:23 PM
Monster Max (F310C) 1.17 Cutoff Voltage 5.0V Use when running a battery pack with 7 or more NiCD or NiMH cells.
Monster Max (F310C) 1.17 Cutoff Voltage 6.0V Use when running a 2 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage 9.0V Use when running a 3 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage 12.0V Use when running a 4 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage Auto Li-Po Use this for all applications where you are using Lipo batteries. When selected, the controller will detect the number of Lithium Polymer cells in series in your battery pack, and set the cut off voltage to 3 volts per cell. When you plug the battery pack into the controller, after the initialization tones the controller will flash and beep the number cells it counted, so you can confirm the controller setting. If the cell count is incorrect, make sure your batteries are charged and the correct cell count is flashed BEFORE flying. Note: Do not use Auto Lipo with NiMH or NiCad cells.
Monster Max (F310C) 1.17 Motor Timing Lowest (0) Best for bashing
Monster Max (F310C) 1.17 Motor Timing Low (5) Good for bashing, and racing with the fastest motors
Monster Max (F310C) 1.17 Motor Timing Normal (10) Good for bashing or racing, with most any motor
Monster Max (F310C) 1.17 Motor Timing High (15) Be careful about motor heat (max safe temp is 200F) when using this setting. High Kv motors will get very hot very fast
Monster Max (F310C) 1.17 Motor Timing Highest (20) Extreme caution necessary for almost any motor - be sure to check motor temps often.
Monster Max (F310C) 1.17 Motor Timing MINIMUM na
Monster Max (F310C) 1.17 Motor Timing MAXIMUM na
Monster Max (F310C) 1.17 Motor Timing INCREMENT na
