triggeraa
triggeraa's Avatar
02.04.2008, 02:06 AM
Thanks for the positive comments. Still have some work to do but the build went fairly fast. I like the stock shocks as they are very beefy and in new condition. I used associated 40w fluid. I will try them out and see how it goes. Team3six. One of the things I changed about my build is not using an elevated deck for the electronics as I wanted a lower center of gravity. I also used xtm mammoth rear dogbones as they are much stronger than grafting the two halves together. I should be receiving the 2nd vxl motor and esc in a day or two. I will post performance numbers once everything is sorted out. Thanks once again.
Name:	DIGI0021 (Medium).jpg
ID:	3960   Click image for larger version
Name:	etk5 (Medium).jpg
