azjc
02.04.2008, 06:47 PM
Originally Posted by skellyo View Post
On 4s, a 540 12S would be a decent motor. Or, if you don't mind having to deal with a 5mm rotor shaft, a Neu 1509/1.5Y would probably be an awesome motor for it.
when you say "dealing with a 5mm shaft" do you mean using pinions for a 5mm shaft and not the 3.17 shaft, I do like the idea of a beefier shaft, and what differences would there be between the 2 motors you have listed I have seen them in the online store, and would there be any meshing issues with a 5mm pinion and the stock spur
