02.04.2008, 06:57 PM
The only issue with the 5mm shaft is getting 5mm bore pinions in 32P and then having to swap the spur over to a 32P spur...or buying Mod1 pinions and a Mod1 spur. It's not anything to stop you from buying a Neu, just realize you can't just drop it in without pricey pinions and swapping the spur.
