Takedown
WARNING: May become violent.
Takedown's Avatar
02.04.2008, 11:04 PM
Originally Posted by Happywing View Post
Hey TD - If you don't have holes in the MM case already, do that. It really helps cool it down. Blowing a fan through those holes also helps big-time. You can put a hole in the bottom of the case and have fans on top and bottom too, if it will fit.
I thought about doing that for awhile but gave up on the idea because it voids the warranty... I will on the other hand blow one or two fans over it eventually.
