Originally Posted by fkadir
So you just glue the spacer and battery mount together? Dat would eliminate screws protruding into the battery tray..
I use really short flathead screws, a few into bottom of spacer and a few in top through the battery tray, countersunk so the heads are smooth with the inside of the battery tray. Then I throw little thin padding in there to cover them up.
